Using the exact same PC, if i go to http://support.xxxxxxx/scp I am presented with the login screen when I use Chrome or MS Internet Explorer, but if I use MS Edge I get 'Hmm....cannot reach this page'. Personally, I never use Edge and tested the system using Chrome and Safari, but not Edge. Now we've gone live, anyone using Edge is having this problem.When I say hyperlinks, I refer to the ones in the emails that osTicket sends out. I have not changed these at all, and these work perfectly with any browser other then Edge. If a user has Edge as their default browser, they cannot use these links.I would like you to try and connect to my server to see if your installation of Edge does work - can I send you the link privately?
