@[deleted],
osTicket (v1.10.1)
- I disable: “Require login to view any attacment”
- Change loglevel from “warning” to “error”
- No log error in osticket today, last 24 juli 2018 was below, a lot of identical below errors, i solved it restarting osTicket package via synology package center
Looks like full database storage? I have not more than 100 files each averagev2 mb.
Looks like i need to add ip shown in log errors or ip adres of my server? Dynamic ip to Office 365 SMTP relay?
Office 365 relay emails on your behalf by using your public IP address (or a certificate) to authenticate Office 365. To do this, you'll need to set up a connector for your Office 365 account, which is what makes this a more complicated configuration.
Can't change size of file (Errcode: 28 "No space left on device")
---- Backtrace ----
#0 (root)/include/mysqli.php(204): osTicket->logDBError('DB Error #14', '[SELECT COLUMN_...')
#1 (root)/include/class.orm.php(3133): db_query('SELECT COLUMN_N...', true, true)
#2 (root)/include/class.orm.php(3189): MySqlExecutor->execute()
#3 (root)/include/class.orm.php(2932): MySqlExecutor->getRow()
#4 (root)/include/class.orm.php(276): MySqlCompiler->inspectTable('ost_content')
#5 (root)/include/class.orm.php(228): ModelMeta->inspectFields()
#6 (root)/include/class.orm.php(2761): ModelMeta->getFieldNames()
#7 (root)/include/class.orm.php(1393): MySqlCompiler->compileSelect(Object(QuerySet))
#8 (root)/include/class.orm.php(1761): QuerySet->getQuery()
#9 (root)/include/class.orm.php(1458): ModelInstanceManager->getIterator()
#10 (root)/include/class.orm.php(1332): CachedResultSet->__construct(Object(ModelInstanceManager))
#11 (root)/include/class.orm.php(1149): QuerySet->getIterator()
#12 (root)/include/class.orm.php(1172): QuerySet->all()
#13 (root)/include/class.page.php(209): QuerySet->one()
#14 (root)/include/class.config.php(605): Page:('1')
#15 (root)/index.php(41): OsticketConfig->getLandingPage()
#16 {main}
Logdatum: dinsdag 24 juli 2018 14 IP-adres:
Mailer Error
Unable to email via SMTP.office365.com Failed to send data [SMTP: Invalid response code received from server (code: 550, response: 5.7.60 SMTP; Client does not have permissions to send as this sender
