I want to give a response about a ticket but not resolve it yet, and I can't, and it appears the next mistake
I put it an image, I don't know if you can see it
The mistake says:"The lock you hold on this ticket will expire soon. Would you like to renew the lock?"
no image attached to thread.I would bet that you have a timezone wrong some where do that the lock is expiring immediately.Check: mysql, php, webserver (if it has one), host OS, osTicket's timezone, and your agent profile.
.. thanks I will try
Ok, all my timezone are conected with the system timezone, except the osTicket's timezone, I got this:How can I connect the timezone of osTicket's with the system timezone
timezones aren't connected to a system time zone... You set the time zone in the appropriate configuration files/db for the products that you are using.The image that you posted is what your PHP is reporting. So you would edit your php.ini and set the time zone in the file.open the file.locate the date.timezone line. Set your timezone.save the file.restart the webserver software.
