Attachments issue in 1.9.15
I am having an issue with attachments to tickets in 1.9.15. This may have happened before in earlier versions but I don't know.
I can upload the files OK but when I come to download them all binary files are corrupted. Every file appears to be 2 bytes bigger than the uploaded version. This is OK for text files but not for binary files. If I do an octal dump of the uploaded file and the downloaded one, the first couple of lines of the original file are:
0000000 045520 002003 000024 004000 000000 056072 046133 143136
0000020 006062 000047 000000 000047 000000 000010 000000 064555
and those of the downloaded file are:
0000000 020040 045520 002003 000024 004000 000000 056072 046133
0000020 143136 006062 000047 000000 000047 000000 000010 000000
i.e. the two octal bytes 020 and 040 are being pre-pended to the file. The content of the downloaded file is identical to the uploaded one after that. Has this been noted before and how can I fix this?
  • Have never seen this before…also I don’t know why bytes would be added to the file…
    have you tried in all browsers and different OSs?
    Also, any errors via Apache/PHP?
  • edited March 1
    Thanks for your response. I am investigating what you have suggested but could you answer the following.
    I am retracing my steps. I upgraded our original 1.6ST version as follows
    I downloaded osTicket 1.7.5 and 1.9.15 and now have two upload directories which I have called "upload-1.7.5" and "upload-1.9.15".
    We have a lampp installation on a Debian 6 server. The installation is in /opt/lampp/htdocs/csportal/osticket
    1. copied upload-1.7.5/* over /opt/lampp/htdocs/csportal/osticket/
    2. Logging onto osticket/scp requests me to upgrade which goes OK.
    3. Log off from osticket
    4. Take a dump of the new MySQL database and a copy of the new osticket directory (for my purposes)
    5. Copy uploads-1.9.15/* over /opt/lampp/htdocs/csportal/osticket/
    6. Log onto osticket/scp and follow the upgrade instructions. This goes OK.
    7. Take a dump of the new MySQL database and a copy of the new osticket directory (for my purposes)
    However, when I try to download an attachment that is a binary file from a ticket under the new 1.9.15 installation the downloaded file is corrupted. I can upload files to tickets OK but when I come to download the attachment it is alwasy corrupted
    Am I following the correct upgrade procedure?
  • edited March 1
    Everything looks okay in the procedure.
    Although honestly I think that you could have skipped the 1.6 -> 1.7.x and just done 1.6 -> 1.9.
    If I remember correctly, in 1.6 attached files were stored on the file system and those were migrated into the DB in 1.7.
    You could try installing the Storage :: Attachments on the Filesystem and migrate them back from the DB to the filesystem and see if that helps.
    Meanwhile I brought this thread to the attension of the devs so maybe one of them will have seen this before.
    Oh, and were ytou seeing any PHP errors?
  • Hello,
    Many thanks,
    I've checked the Apache logs and there's nothing there. Unfortunately I did this quite a while ago and have only just noticed the download issue. I've no idea why I didn't notice it befor.
    I think I did the 1.6 to 1.7.5 to 1.9 route because it wouldn't work going directly from 1.6 to 1.9. I'll give it another go.
  • Hello,
    Success, I believe! There must be some discrepancy between the storage format for attachments in 1.7.5 and 1.9.* as directly upgrading 1.6ST to 1.9.15 seems to have done the trick. Attachments are now being uploaded and downloaded ok.
  • Huh... Thats really weird.  Well thanks for letting us know
  • Hello,
    Two more things about the Storage::Attachments plugin.
    1. The attachments from osTicket 1.6 still exist under osticket. Will these be over-written by enabling the plugin?
    2. If installed and enabled does that mean all future attachments will be stored on the file system instead of in the database?
  • 1. No.
    2. Yes.
    As a side note if you are moving attachments to the file system you should probably migrate the ones in the DB to the file system as well so that you have them all in one place.
  • Many thanks. I have just downloaded the plugin:
    v0.3, released Apr 2 2015
    Is that the latest one?
  • Looks like it from my perspective :)
  • edited March 13
    I'm sure I've installed it correctly and configured it OK. See the two attached screen shots. However, when I upload a file it's not on the file system so it must be in the database. The specified attachments directory has read and write access for the web server. The old attachment from the 1.6 version already existed in the /attachments/ directory. Is there anything else I need to do to ensure that
    1. these are used instead of the ones in the database?
    2. that new uploads are stored in the filesystem
    822 x 104 - 24K
    926 x 152 - 13K
  • After you upload, configure and enable it.
    You still have to go to:
    Admin panel -> Settings -> System
    scroll to the bottom.
    Under "Attachments Storage and Settings:"
    set "Store Attachments:" to the new option.
  • Thanks for your quick response. Sorry, I had already done that. I followed the instructions on
    which I found on
    I tried initially changing the permissions on the attachments to 777 but still no joy. You say on that post
    "did you migrate the files from the DB to the file ssytem after installing and enabling?"
    How do you do that?
  • You would use the manage.php script at a command line.
    php setup/cli/manage.php file migrate --backend D --to F
  • Thanks. I'll give it a try. Will any/all files that are already under attachments (from 1.6 installation) be overwritten by this process or, if they already exist will they remain unchanged?
  • Hello,
    I need to revisit the original issue. I didn't have a lot of joy with the Storage::Attachments plugin but I will come back to that. I was a bit premature in saying that my original issue of uploaded files being corrupted had been resolved. If I upload any file two bytes are prepended to the file. This is OK for text files and doesn't always seem to affect, say, PDF files. However, it always seems to affect MS Office and LibreOffice documents. I have tried to attach a LibreOffice spreadsheet file (.ods extension) to this post that was uploaded and then downloaded from a ticket but am not able to: when I select the file I get an error as in the attached message. Could this be a related issue
    456 x 148 - 8K
  • Not sure the error message got attached to the last post so attaching it to this
    456 x 148 - 8K
  • @catfood
    Yes, that can very well be the issue. Anything Windows is known to not play well with osTicket (or anything else for that matter). I would try doing a test upgrade to v1.10.1 to see if v1.10.1 fixes this. If that doesn't help test with non-windows files to see if you get the same results.
