Forms and question length
OSTicket is set up to show a custom form when a certain help topic is chosen. There is quite a bit on the form and some of the text labels on the form go beneath any text boxes, choice boxes or anything like that. Is there a way of increasing the text area for the labels?
Thanks
  • Sorry i'm not real sure what you mean.have you tried adding section breaks?
    Maybe a screen shot would clarify.
  • Hi,
    I have attached an image.
    Hope it's a bit clearer. I want to move those dropdowns to the right so the full text can appear on one line. If i use alt+255 to add a blank character to make it seem like one long word, the text simply goes underneath the drop down boxes.
    Thanks for your help
