DATA BASE migration problem
I am getting problem while upgrading from 1.8 to 1.10.1
[ALTER TABLE `ost_filter` ADD `topic_id` int(11) unsigned NOT NULL default '0' AFTER `form_id`] Duplicate column name 'topic_id'
Applying updates to database stream: core
In order to upgrade to this version of osTicket, a database migration is required. This upgrader will automatically apply the database patches shipped with osTicket since your last upgrade.
The upgrade wizard will now attempt to upgrade your database and core settings! Below is a summary of the database patches to be applied.
v1.9.0: Add client login feature
v1.9.0: Add organization features
v1.9.0: Move organization support from UserAccount to User model.
v1.9.4: Custom Ticket Numbers and Statuses
v1.9.4: Add properties field and drop 'resolved' state
v1.10.0: Make editable content translatable and add queues
v1.10.0: Add role-based access
v1.10.0: Add support for ticket tasks
v1.10.0: Make fields disable-able per help topic
v1.10.0: Add collaborators to tasks
v1.10.0: Add events to the ticket thread
v1.10.0: Access Control 2.0
