when i setup cron jobs i can only select a local file drop a drop down so i select:
/Support/api/task/cron.php
and i get this error from my hosting company:
-----Original Message-----
Sent: 13 March 2013 13
To: rmrosser@binarytechniques.co.uk
Subject: Cron /usr/bin/GET -t 300 -C 'binarytechniques:*FIELD REMOVED*' 'http://binarytechniques.users36.interdns.co.uk/Support/api/task/cron.php'
cron.php only supports local cron jobs - use http -> api/task/cron
when a new ticket is submited i get a notification but if someone emails the email address setup i dont unless i login
can you help?
