Bugfix: index.php > frontpage is not fully translated
Not all strings on the frontpage are fully translated. Because of a missing function for translated teaser, you have to do at first this bugfix. Click here!
affected file: index.php in root directory
Open "index.php" in the root directory and replace in
line 64 the code "<?php echo $C->getName(); ?>" with the following "<?php echo $C->getName(); ?>"
line 70 the code "echo $F->getQuestion(); ?></a></div>" with the following "echo $F->getLocalQuestion(); ?></a></div>"
After this save the file and upload it in the right place.
Best regards,
Jürgen
  • Hi
    You mentioned to edit the line 64 on index.php. But you are replacing it with the same:
    -->> line 64 the code "<?php echo $C->getName(); ?>" with the following "<?php echo $C->getName(); ?>"
    What sould it be exactly?
    Thanks
