Hello,Is there a way to programmatically put osTicket into maintenance mode? If I want to perform a backup, I would prefer the system to be in maintenance/offline mode before taking a copy of the database. Ideally, I would like to be able to do this via the CLI.For example, ownCloud allows you to put the application in maintenance mode using the following:sudo -u www-data php occ maintenance --onsudo -u www-data php occ maintenance --offTaken from: https://doc.owncloud.org/server/9.0/admin_manual/configuration_server/occ_command.html?highlight=occ#maintenance-commands.Is this possible?Thanks.
