Sorry, here are some more important informations:I tried setting the port to 636 and got the following message:Ldap Server: servername.domain.xyUse TLS: Yes-->
TLS could not be started: Can't contact LDAP server: Unknown Net_LDAP2
Error (-1): Unable to bind to server servername.domain.xyBut if the plugin only supports tls, at it seems to be then it will only work the common port 389.Ldaps / ssl works on port 636, but this cant be configured in the plugin interface?
Server Information
osTicket Version v1.9.14 (8b927a0) — Up to date
Web Server Software Apache/2.4.7 (Ubuntu)
MySQL Version 05.05.1953
PHP Version 5.5.9-1ubuntu4.20
PHP Extensions
imap Used for email fetching
xml XML API
PHP Settings cgi.fix_pathinfo "1" is recommended if AJAX is not working
date.timezone Setting default timezone is highly recommended
