why i frequently got this email? what error actually?osTicket Version v1.9.12 (19292ad) — Up to date(root)/attachment/y/ysDzMSoyCHZXjga3G7yxrjzQvhz3A3Jk: Unable to delete file#0 E:\helpdesk\include\class.file.php(150): FilesystemStorage->unlink()#1 E:\helpdesk\include\class.file.php(633): AttachmentFile->delete()#2 E:\helpdesk\include\class.cron.php(49): AttachmentFile:()#3 E:\helpdesk\scp\autocron.php(61): Cron:()#4 {main}
php error logs
PHP Fatal error: Uncaught exception 'IOException' with message 'E:/helpdesk/attachment/B/BwCNFXfcKKOLCUywK30AQPpDg5-3C6kQ: Unable to delete file' in phar://E:/helpdesk/include/plugins/storage-fs.phar/storage.phpStack trace:#0 E:\helpdesk\include\class.file.php(150): FilesystemStorage->unlink()#1 E:\helpdesk\include\class.file.php(633): AttachmentFile->delete()#2 E:\helpdesk\include\class.cron.php(49): AttachmentFile:()#3 E:\helpdesk\scp\autocron.php(61): Cron:()#4 {main} thrown in phar://E:/helpdesk/include/plugins/storage-fs.phar/storage.php on line 59
Q: why i frequently got this email? A: My guess is that you have a permissions error.Q: what error actually?A: You provided the answer. it is "Unable to delete file"
permission has been given for that folder..refer attachment.. anything missing?
Showing us the base folder does not show us the sub folder or the file permissions.
ntoizer..see attachment..pls assist..
The file that it cannot delete is:E:/helpdesk/attachment/B/BwCNFXfcKKOLCUywK30AQPpDg5-3C6kQ
new error..unable to read(root)/attachment/E/Ecduckyy9cTNKRr3DYRD9aQNsx7EBe1I: Unable to read from file#0 E:\helpdesk\include\class.file.php(121): FilesystemStorage->passthru()#1 E:\helpdesk\include\class.file.php(255): AttachmentFile->sendData(false)#2 E:\helpdesk\file.php(36): AttachmentFile->download(false, '1461801600')#3 {main}
The file that your system cannot read is: (root)/attachment/E/Ecduckyy9cTNKRr3DYRD9aQNsx7EBe1
I already try to delete all file&folder on attachment folder.. But when upload new attachment this error occur..still same..for example : (root)/attachment/c/coGOpmUsgWIZQgN9JkXTt5GUQVxniGh0: Unable to delete file#0 E:\helpdesk\include\class.file.php(150): FilesystemStorage->unlink()#1 E:\helpdesk\include\class.file.php(633): AttachmentFile->delete()#2 E:\helpdesk\include\class.cron.php(49): AttachmentFile:()#3 E:\helpdesk\scp\autocron.php(61): Cron:()#4 {main}i check this error on that folder..but there is nothing file on c folder..
What user does your webserver run as? I certainly hope that it is not administrator.
yes.. it is administrator..
i try to change attachment folder..but the error same..i try to upload 4 file on same ticket..2 file succes upload... 2 file not succes.. error when try to open back...the system tell cannot find that file..E:/attachment/x/xlccHQ77CehWhxZLD_hbrWS_7G71--HU: Unable to read from file#0 E:\helpdesk\include\class.file.php(121): FilesystemStorage->passthru()#1 E:\helpdesk\include\class.file.php(255): AttachmentFile->sendData(false)#2 E:\helpdesk\file.php(36): AttachmentFile->download(false, '1461974400')#3 {main}
after i do the investigation..i found that the system create file on attachment folder using Owner IUSR.. but the attachment folder still owner Administrator.. maybe this cause a problem cannot read/delete file..how do i solve this problem on windows server 2012 r2? how do i change the owner to Administrator for attachment file?in other word..system create file on attachment folder by using Owner IUSR not as Administrator.. correct me if wrong..
Webserver software?IUSR is IIS.IIS does not run as administrator. It runs as IUSR... which means those folders should be owned and have permissions that allow your webserver user to read/write/etc.
What u mean by webserver software? Example?e? I just install php manager on iis by using web platform instaler..
I just folow this article - https://docs.google.com/document/d/1WM6BlIdQLQLIPkhbRpNkO3Z9AFPWGFbI0H7GA42b-N0/pub
webserver software = IIS. Apache. NGINX. etc.
Im using iis..
Is there any solution for this?
Yes. Fix your permissions.
