Issue in Upgrading Osticket Installation
I Need to update Version osTicket (v1.9.1) to current (osTicket Core, v1.9.11), I have done the following things
Add upstream -- git remote add upstream https://github.com/osTicket/osTicket-1.8
Fetch changes ("git fetch upstream")
Checkout to develop branch ("git checkout develop")
Merge with my changes in develop ("git merge upstream/develop")
Pushed code(include all tags) to my gitbug account
Pull all codes to my server
Deployed changes to document root through "php setup/cli/manage.php deploy -v /path to my os-ticket installation"
Run the update script, it shows "Upgrade Completed!"
But it shows current version as v1.9.7-140-g5788136 (5788136)
I run the command "git describe", it display "v1.9.11-11-g5788136"
I can see tag v1.9.11 in my git hub account.
But system still shows version as v1.9.7-140-g5788136 (5788136)
Kindly share your ideas
Thank you
  • I would recommend only downloading and installing the official archives from http://osticket.com/downloads
  • edited July 2015
    @ntozier
    Thank you for your reply, I have identified the issue.
    When I fetch code from git, I didn't pull the git tags too before deploying changes to document root , this is the key.
    The issue I have faced is described below.
    1) The upgrade process will happen based on the constant "THIS_VERSION" in bootstrap.php
    2) This constant is set by php installer (php setup/cli/manage.php)
    3) The installer get the value by running "git describe" (this is why we need to pull git tags as well)
    4) Unfortunately  I didn't pull git tags before I deploy changes to document root.
    By the way kindly describe how can we upgrade osticket version from archives.
    I did upgrade the way I described in the first comment because I found an article http://osticket.com/blog/86.
  • version numbers are different, but the proceedure hasn't changed.
    http://www.tmib.net/upgrading-osticket-1812-current-19rc
  • edited July 2015
    @ntozier
    Thank you for your response.
    So how can we track custom changes?
    So how can we use this article http://osticket.com/blog/86
  • Q: So how can we track custom changes?
    A: That would really be a decision for your staff to make, but you could always use github.
