Basically I had a task to come up with a better solution than the very minimal "Support" link on our website (which simply sends an email to one person regardless of the issue and provides no real tracking or anything else).
So, after some research I built a test instance of osticket on a spare Linux box I had lying around and our CEO loved it so much he wants it implemented ASAP.
Basically our current webserver runs on a Windows IIS VM which lives on a Linux server. I'm thinking maybe the best thing to do is build a Linux VM on that box for osticket, and then just link from the primary page to this server?
Does that make sense? Anybody have maybe a better solution, as I imagine others have used osticket as a support solution for their existing website just not sure the best way to go about this. We'll also be using it for internal ticket tracking as well.
I should note that right now I only have one physical box in our DMZ, and due to budget restrictions at the moment I don't have the option of buying/building another right now.
