Hi, i recently installed the latest osTicket (v1.9.5.1) and got the following warning:PHP IMAP extension — Required for mail fetchingI host osticket installation on AWS Ubuntu 14.04 running apache and nginx (as reverse proxy). I can confirm (from info.php) that IMAP has been correctly installed and configured.What i don't understand is why osticket installation says that PHP IMAP extension is missing. Can anyone help me with this?Cheers
You need php-imap. That's not the same as IMAP, it's a separate package. I believe the Ubuntu command would be:sudo apt-get install php-imapIt should be in the default repositories. If not, then Google it.Jack
On Ubuntu/Debian the command to install would actually be:sudo apt-get install php5-imap
@[deleted] -Good catch, thanks.Jack
Very welcome. Pesky little 5's. :)
