Responsive Bootstrap custom theme for osTicket
I have created a responsive Bootstrap based  theme for the clients section of osTicket. This gives the clients a better visual and functional experience when compared to the default setup. The layout is fully responsive that enables effective usage on mobile devices. The ticket admin section is not customized The theme has customizable logo, customizable hero section on the homepage, social media icons of the footer etc. This theme gives a complete makeover to the client section of your support ticket system. The customization is compatible with the latest 1.9.5 version of osTicket.
More details here - http://www.web2feel.com/osticket-responsive-custom-theme-built-on-bootstrap-framework/
Please check the live preview and screenshots before you purchase the file. You can create a user account to check the client section of the theme. Please try checking it on a mobile device as well.
  • Looks nice.
    (Personally I think that I would compact it a little to remove some of the dead white space but that's just my personal preference.)
    As a side note Re: "The customization is compatible with the latest 1.9.5 version of osTicket."
    The current version is actually 1.9.5.1.
  • Thank you for the comments ntozier, Yes, you are right about the version error. I just so happened that 1.9.5 was the last release when I made that draft.
    Thanks
  • Nice Work Jinson.
    One question.
    Which support will have this? What i mean is if i buy this version, when osticket release new versions, will you upgrade or i will have to stay in 1.9.5.1 to use it?
    The upgrade will be free of charge?
    Thanks in advance!
    Regards,
  • Hi,
    Yes, when a new version comes out I will provide and update for it. Updates are free.
  • Thanks for the theme. I am already using it.
    Also thanks for the update you made for 1.9.5.1.
    Its working great!!
    Regards,
  • Thank you. Good to know you like it.
  • hello.
    i'm interested to your job. I've just installed the latest osticket version.
    Do i will have issues installing your theme on it?
    regards
    tony
  • Thank you. This is not exactly a theme, but it is a customized version of osTicket itself. So you can install it just like how you would install osTicket.
  • Hello..
    I am very concerned and interested in your theme, and I was wondering is this theme support RTL Languages such as Arabic Language..
  • Hi,
    I am sorry . It does not include RTL style.
