I'm trying to set up a ticket filter so that, depending on the priority, a new ticket created via email will be auto-assigned to a specific group.If I send an email marked high priority, osTicket creates a new High priority ticket, as expected. But I can't get it to auto-assign the ticket.In the filter, when I pick "Ticket / Priority Level" , Match Any , and put "High" or "high" (without quotes) in the comparison value field, the filter never triggers. I've tried Equal, Contains, Starts With, Ends With, and even Matches Regex with "High|high" in the box.The filter triggers and auto-assigns correctly if I use some other criteria such as User/Email Address. I just can't seem to get it to trigger on the ticket priority level.What am I missing? Is there some special nomenclature I should be using to do a priority comparison?Here's my setup:osTicket version: v1.9.3 (bba9ccc) on Ubuntu 12.04.1 Plugin: LDAP Authentication and Lookup, authenticating against Active Directory on Win Server 2003 R2Apache/2.2.22 (Ubuntu). MySQL Version 5.5.38PHP Version 5.3.10-1ubuntu3.14. IMAP c-Client Version 2007e
