osTicket (v1.9.3)RedHat 6.5I just installed the latest osTicket and LDAP Authentication and Lookup plugin this morning. My expectation is that LDAP lookup will allow me to have some kind of type-ahead find or list-based selection mechanism when adding staff or creating new tickets. Right now I'm not seeing anything. Worse, while I was able to set up the LDAP Authentication and Lookup plugin without issue, now, whenever I try to save any configuration changes to the plugin, it just sits at a loading screen and never takes the changes. Is there any way I can manually alter the plugin's config?In any case, right now I have no idea if the plugin is simply misconfigured (which would be odd, because auth is working) or if LDAP lookup is not working, but auth is, or if my expectations are wrong. I have no way to test whether or not the LDAP search settings I have are correct.Can anybody help with this?
