Hi,After upgrading to 1.8-Git, none of our attachment/images in FAQ's work. when you view an attachment, the OSTicket header displays, as in the attached image. Is this a bug, or is there a way to fix this.ThanksGary.
I would recommend that you download the installation archive from osticket.com/download. Then see if you still have the problem.
Hi there,Here is the quick fix. Hope it will work for you as well. Going to class.faq.php and did a change on the getAttachmentsLinks() function. Please refer to the attachment.Regards,Sam
