@[deleted] - The filter function works well, and it is likely that your filter is not correctly set up. If another filter with a lower "Execution order" matches the incoming email, and if it has "Stop processing further on match!" selected, then your filter will not be applied. If that is not the case, please post what is on EVERY line of the page where you set up the filter--including the checkboxes. Or, just post a screen shot here.@[deleted] - You should post your question as a new topic. Your issue may be similar, and you may learn from this one, but yours is likely different. It is difficult to assist with two separate issues in the same topic. And if you want to save time, do what I suggested for JBAB in your first post of the new topic.Jack
