Hi thereI cannot get incoming IMAP emails to work. im getting a 504 Gateway Time-outThis is what i have entered below. I have tried using pop unsuccessfully. Any help with info what i am do wrong would be appreciated. Thank you
* Update Status has been enabled
Anyone got any ideas ??
Hey mate,
POP usually runs over port 110. IMAP usually runs over port 143.
dr jazz
Hi thanks for replying.Ive tired those setting but im getting a 504 Gateway Time-out.Warning: imap_open(): Couldn't open stream {mail.mydomain.com/imap/novalidate-cert}INBOX in /home/linweb19/s/mydomain.com/user/htdocs/Helpdesk/include/class.mailfetch.php on line 139
You probably need to use the SSL port, 993, select "SSL" from the Encryption drop-down.
hi ive just tried 993 with no luck. Ive contacted my host and give them access to the software, they couldn't get it to work either.
